Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Pin constraint at 2018 version
2 REPLIES 2
eladm
416 Views, 2 Replies
Hi ,
I use Nastran in cad from 2019 version , From a reason I need to do a simulation with 2018 version.
There is no pin constraint only structural
How can create the pin constraint in the old version ?
thanks
Labels (1)
2 REPLIES 2
Roelof.Feijen
in reply to: eladm
Hello @eladm ,
You will need to create a Cilindrical Coordinate System and use that coordinate system with your structural constraint. See the video below:
Although the video was created with version 2021, the procedure for 2018 is the same. Most of the time I use workpoint to select the coordinates for the Origin, Axial direction (Z) and Radial direction (R).
You can also select sketch points, vertices or specify the coordinates yourself.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
eladm
in reply to: Roelof.Feijen
Thank you
Technology Administrators
