NASTRAN In-CAD 2019 with Impossibly Slow Interface
Good Afternoon.
I have downloaded and installed NASTRAN IN-CAD 2019 along with Inventor Pro 2019. I'm working on the 30day trial as an evaluation of the software.
The model I'm working with is an assembly with 189 midsurfaced pieces, and 2 solid pieces, 14 connectors (2 springs, the rest are rigid). Part count is 227 discrete pieces. Overal model dimensions are 7'x7'x16' and I have it meshed with 2in elements throughout, not utilizing the mesh table for any refinements. The results log file shows 77220 elements. This is a "mid-size" model in comparison to the rest of the company.
The computer I'm working on is a rather new ThinkStation P320, i7-7700 @ 3.6GHz (8-core), 24.0GB RAM, Nvidia P2000 w/6GB RAM, and 256GB SSD running windows 10. The computer is screaming fast in all other programs, and even when doing advanced modelling within Inventor, advanced calculations in MathCAD, and even when compiling code in Visual Basic.
I'm finding the interface to be extremely difficult to work with. The solver appears to be running rather quickly, but the interface itself for viewing results, as well modifying part geometry (mid surfacing, meshing, etc) is impossibly slow. Saving once midplaned is also prohibitively slow (a single save took almost 10 minutes this morning). Other things like changing the visibility of the CAD bodies from the ribbon has taken several minutes as well. The solver ran in just under two minutes.
I found some threads here discussing disabling the integrated video card and seeing some improvements, and have done that. It worked.....sort of....There is still odd behavior and ridiculously slow times to do the most basic things basic things in the interface.
Is there anything I can do to speed up this model in the interface? Is there a guide I can be pointed to on how to optimize settings within NASTRAN to help with this odd situation? Should I be deriving a single part and doing the analysis on that instead of working within the Assembly directly? Any help would be greatly appreciated, as NASTRAN has some very real benefits over ANSYS in our situation, however if this interface isn't sped up it will be a non-starter.
