Compression Only Supports and Springs
05:30 PM
What is the best way to define compression only supports, with infinite rigidity? Basically, I want a support (constraint) that I can apply to a part that acts like a pin in compression but free in tension. For instance, a steel plate bearing on concrete with a bending moment applied to the plate. I want the plate to not be able to push into the concrete, but still be able to pull away from it. And i don't want to model the concrete at all.
Similarly, how can you define a compression only (or tension only) spring? We use these in normal structural analysis quite often, say to simulate soil stiffness, but can't see how i can do it in Nastran in-cad.
Thanks.
