Not able to generate report for MODAL FREQUENCY RESPONSE ANALYSIS
Aadithya01
Advisor Advisor
Aadithya01
Hey Guys,
I was running a modal frequency response analysis for a fixture that I was doing . And tried to generate a report . When I right click the corresponding  analysis , the option to generate report is greyed out .. Cant nastran in cad generate a report for Modal frequency response tests .
Please see the below image .
John_Holtz
Autodesk Support
Autodesk Support
Hi @Aadithya01
According to the documentation, reports can only be generated for linear static stress.
I found two posts on the Ideas page related to similar topics. You may want to vote for either or both of these:
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
