- Mute
- Permalink
- Report
Hello folks,
I am trying to analyze pipe under external pressure which is applied inside the weldolet connection. I defined the nonlinear material and wana see stress as per ASME Section VIII Div 2.
I setup the nonlinear static analysis and tried about 10 times and it failed/crashed.
It is running smooth until few iterations and then it switched to "Subiterations" and this is where it took a lot of time and then crashed.
I am attaching the files, so if any of you on this forum can help me plz. Model is defined fully, i.e., geometry, BCs, loadings, material (non-linear one 'Plastic option' stress-strain curve [attached as well]), meshing, Surface Contacts (as this is welded so all contacts are bonded). All files are in zip file.
I am using Inventor 2018 with Nastran In Cad on Windows 10 64 bit OS.
