Hi @jlkono
I think the load should be gravity, and the constraints are the contact with the support pier and symmetry constraints (if you do not model the entire vessel). This schematic shows the model in simple terms.
- The physical vessel sitting on several piers.
- The simplified engineering model. Although the piers are probably spaced uniformly, the stiffness of the vessel is probably not uniform along the length. In this situation, the maximum displacement may not be centered exactly between the piers. The "symmetry" lines shown in the image are where the maximum displacement occurs (the slope of the displacement is zero).
- The portion of the vessel modeled. The constraints are the support by the pier and symmetry constraints on the two ends where the model is cut away.
Note that the Y symmetry constraints on the left and right side are not a completely accurate way to setup the analysis, but I do not know how to do it more accurately. The problem with the two sets of Y symmetry constraints is that they prevent the model from getting longer or shorter in the Y direction. (The Y symmetry constraints prevent the nodes from moving in the Y direction.) The ideal constraints would be Y symmetry on the left side, and the nodes on the right side must translate the same Y displacement (either +Y if the vessel gets shorter, or -Y if the vessel expands due to the displacements). In other words, the nodes on both planes remain in a vertical plane, the plane on the left side does not move, but the plane on the right side can translate in the Y. This setup could be done with a multi-point constraint, but Inventor does not have that capability.
I suggest starting with a static stress test model to get a better understanding of the symmetry constraints. You can create a "full model" on several supports (just a simple block on several supports, nothing fancy), and then do a "symmetry" model on one support. The results should be the same.
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
