Nonlinear axial compression of a tube - fatal Error E5076: Maximum number of bisections reached
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Please help
I'm relatively new to Nastran so I apologise if there is a simple solution to this.
I have a thin walled tube (75mm OD x 2mm thick x 150mm long) and I want to apply a load to the end. (nonlinear buckling)
I have set up a custom nonlinear material (though have also done a sanity check with a standard nonlinear one) and no matter how I set up the analysis I always get a failed solution.
The obvious way to set it up would be to fix the bottom and a apply a load to the top.
I have tried variuis constraints: fix the bottom edge, fix the bottom in all directions accept along its surface plane. split the tube along its length and put a symmetry constraint there.
I have also tried adjusting the mesh, changing the steps, basically anything I could but I always get the same error.
I must be doing something wrong as I cannot think of a simpler analysis.
