Nodes missing in .BDF / TET10
jens.hornschuh
jens.hornschuh
Hi There,
When useing Nastran INCAD 2019 (13.2.0.168), I face the issue, that CTETRA elements (TET10) are not properly written to the corresponding .bdf file, which we would like to postprocess in a "real" patran/nastran environment.
The attached screenshot shows the trouble:
In file .nas (left side of the picture), all CTETRA elements have 10 assinged nodes (as it should be), whereas the corresponding .bdf (right side of the picture) only has either 9 nodes (red circled) or even 7 nodes assigned (blue circled). => this goes on for the following TET elements but I only highlighted the first two.
Any idea? Thanks and a happy new year to all of you 🙂
John_Holtz
Autodesk Support
Autodesk Support
Hi @jens.hornschuh
How are you creating the BDF file?
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
jens.hornschuh
Dear John,
thank you for your reply.
I allowed TRSLDFGMDATA and TRSLMODLDATA (=ON) by editing the parameters at the bottom of the model tree to obtain the output files.
[cid:[email protected]]
John_Holtz
Autodesk Support
Autodesk Support
Hi @jens.hornschuh
I have reproduced the behavior, so I will report it.
In my test model, it appears that the midside nodes that are involved in the contact between parts are missing from the BDF file. I have no idea why that would happen or if there is some way to prevent it from happening. (Now that I write that, changing the parameter ENHCCONTACTRSLT to ON may fix the problem, and then re-run the analysis.)
The other option is to copy the CTETRA lines from the .nas file to the .bdf file. The node numbers are not going to change!
John Holtz, P.E.
