Modal Frequency Response Example Help
pzachNKATE
pzachNKATE
Version: Nastran 2021, Modal Frequency Response
I am following the tutorial outlined here: https://knowledge.autodesk.com/support/inventor-nastran/getting-started/caas/CloudHelp/cloudhelp/202...
As you can tell from the image below, response is not as expected.
John_Holtz
Autodesk Support
Autodesk Support
Hi @pzachNKATE
I agree that your results are not correct. I think you missed step 2, but I do not know on which page you missed step 2. 😉 (I am joking. No one can determine what you did differently without having your model. Please attach the .ipt file to the forum.)
Also, did you review the warnings and errors in the log file? There might be a warning that explains what is wrong in the analysis. (See How to locate the log, output, and Nastran file.)
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
pzachNKATE
John,
Thank you for the quick reply. ipt is attached. Yes, there is one error:
WARNING E5052: EXCESSIVE ERROR MEASURE DETECTED FOR ONE OR MORE MODES
Peter
John_Holtz
Autodesk Support
Autodesk Support
Hi Peter,
You applied a force to a node that is fully constrained. Therefore, there is no load in the analysis, and the results are zero.
You should have changed the load type to an enforced motion and applied an acceleration of 1 in/sec^2. The enforced motion moves the constraint, and the constraint moves the model. (Wow, the problem was with step 2. I guessed correctly!)
John Holtz, P.E.
Autodesk, Inc.
