Hi @martin.alvin
I think they are indicating that you need to use the principal strain. In particular, if the part is in compression, then the minimum principal strain will be a larger absolute value than the maximum principal strain, so you want to use the minimum principal strain value.
The strain can be output by Nastran, but you may need to edit the analysis settings first and check the box to output the strain result.
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
