Maximum absolute value of the principal structural strains
martin.alvin
martin.alvin
Hello!
I need to evaluate according to PED (Pressure directive),
it states max 5% "maximum absolute value of the principal structural strains"
Can i see that in nastran in cad? what is it called?
John_Holtz
Autodesk Support
Autodesk Support
Hi @martin.alvin
I think they are indicating that you need to use the principal strain. In particular, if the part is in compression, then the  minimum principal strain will be a larger absolute value than the maximum principal strain, so you want to use  the minimum principal strain value.
The strain can be output by Nastran, but you may need to edit the analysis settings first and check the box to output the strain result.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
