Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Material thickness is missing
2 REPLIES 2
Sergey_Dukman
194 Views, 2 Replies
Hello.
I have performed a stress analysis of a simple structure.
By some reason, the thickness of the structure isn't present after I use the half-section view.
The same issue is with Nastran also. Why the material thickness is missing?
2 REPLIES 2
John_Holtz
in reply to: Sergey_Dukman
Hi @Sergey_Dukman
The first image is from Inventor Stress Analysis (ISA). I do not have enough experience with ISA to answer why the interior elements are not shown.
The second image appears to be from Inventor Nastran and is sectioned using the Inventor command "View > Visibility > Half Section View". Nastran is not programmed to use that command, so it will not show the internal elements. In Nastran, you need to use the "Section View" command on the plot dialog. "Results > Options > Section View".
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Sergey_Dukman
in reply to: John_Holtz
Many thanks, John.
Technology Administrators
