Linux version system requirements changing
John_Holtz
Autodesk Support Autodesk Support
Message 1 of 1
John_Holtz
Autodesk Support
Autodesk Support
Hi everyone.
Is anyone using Linux to run their Nastran analyses? If so, be aware of the minimum system requirements that will change with Autodesk Inventor Nastran release 2023. (Version 2023 will be released sometime in March or April 2022.) Here are the changes:
  1. Red Hat Enterprise Linux (RHEL): CentOS 7.6 is the min. support OS version on 7.x series.
  2. RHEL: CentOS 8.0 – specific 8.0 version – is removed from supported OS version; 8.1 or higher will be supported.
The above decisions are in alignment with EOL of Extended Support documented by RHEL for these versions.
Time to update your operating system if using an older version.
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Replies (0)
