- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
I'm having some issues calculating life cycles in fatigue analysis. First of all, i've followed step by step the example of "Autodesk University Guide: Don´t get tired of fatigue". It says that: "The Life Contour result is a minimum of 61940 seconds", but when I run the analysis with the same instructions, the Life Contour minimum is 17533,195 seconds. I find that is a big difference and I don't know what's wrong. It would be helpful if there were some pictures in the Autodesk Guide. I'm inserting some pictures of the model and the parameters, maybe someone finds the mistake!
In addition, I've been testing other parts and models, with diferents types of loads, like axial load, but every Life results seems to be wrong comparing it with the hand calculations (I've followed in every case the Goodman modified method, using the book [Shigley] as reference). Between the hand calculations and the simulations Life I've found differences of 1000000 seconds. I'm starting to think that there is some issue in the configuration, but I don't know if I can change something. Any help would be appreciated!!
Thank you,
Ines
