How to use graphs about load-deflection curves in inventor Nastran?
cite10
Observer Observer
cite10
Observer
Observer
I conducted a three-point bending stress analysis through the inventor nastran, and as a result, I would like to use the load-deflection curve. I don't think it's using XY plot, what should I do?
John_Holtz
Autodesk Support
Autodesk Support
Hi @cite10 . Welcome to the Inventor Nastran forum.
You know the load (because you applied it), and you know the displacement (because Nastran calculated it). You can create a graph using Excel.
  • I you ran a static analysis and have only 1 subcase, then you have 1 data point. The graph will be a straight line in Excel from (0,0) to (force, displacement).
  • If you ran a nonlinear analysis and output all the increments, you can create the XY Plot to get the displacement versus load factor, click the button to copy the data to the clipboard, paste the (load factor, displacement) data into Excel, and replace the load factor with the load.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
