- Mute
- Permalink
- Report
Hi everyone,
I am trying to use the stress linearization function to get the Pm and Pb value for a pressure vessel. In order to define the SCL I have to select 3 points, first point and last point to define the SCL line, third reference point to define the local coordinates system. Now I have a problem for define the last point which located inside of vessel shell, since I have a full vessel model (for many cases, I can created symmetric 1/2 vessel then it is easy to define any points, but this vessel I cannot create only half ). I tried to use section view function under plot option, then the model looks OK and it gives me the section view that I want. However, when I selected the point by clicking the node in the view, it still applied to the outside node point which has been turned off by section tool.
What is the easiest way to define a node point inside of a pressure vessel? Or easy way to define any points inside of the enclosed shell? Are there any function like "show/hide elements" in ANSYS?
Thanks!
