Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
How to delete/edit a material in a custom library
1 REPLY 1
simon_trudel
638 Views, 1 Reply
For now, I want to delete a custom material I've created in my custom material library. How can I do this?
At some point, I'll want to create folders of materials in my custom Nastran In-CAD library. Is there a material editor or something? What's the best way to do this?
Thanks.
1 REPLY 1
John_Holtz
in reply to: simon_trudel
Hi @simon_trudel
Both of your questions (deleting a material and creating folders) are done by editing the .nasmat file. The .nasmat file is a text file, so you can edit it using Notepad. (In particular, it is an "xml" format, so if you have some editor specific for xml files, that would be better.)
This article shows the overall format: Nastran In-CAD: Create a custom material library
  • to delete a material, you delete all of the lines from <material name =""> through </material>.
  • to create folders, you add <classification name =""> and </classification> tags.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
