how to add initial strain
tykryu
tykryu
In Inventor nastran 2020, I want to analyze pre-strained (initial strain) polystyrene panel bending with heating.
I found that I have to input initial strain to bulk data(PSTRAIN or INITSTRAIN ?) , but I dont know how to input it.
Please give me the answer.
OS: Windows10
Use software: Autodesk Inventor professional 2020.
johnsonshiue
Hi! Inventor FEA can only do static analysis on isotropic material. It cannot handle heat stress and non-linear deformation. I believe you need to use Inventor NASTRAN instead.
Many thanks!
Software Test Engineer
tykryu
Oh, I'm sorry, I forgot to write explicitly the software I use.
I installed Inventor nastran already, thanks your confirmation.
johnsonshiue
Hi! Then I will move this thread to Inventor NASTRAN forum.
Many thanks!
KubliJ
Hi @tykryu
It is possible to add initial strain to a Nastran analysis. But it will need to be manually added to the deck file.
INITSTRAIN needs to be added to the case control to identify/call the card STRAIN.
With the data looking like:
James Kubli, P.E.
Please marked this as solved if your question has been answered.
