Explicit Analysis
Explicit Analysis
Explicit Analysis
Hi everybody,
talking about the last release of Inventor Nastran 2020, which is the difference between Explicit Dynamics and Explicit Quasi-Static? When using the first and when the latter?
Tutorials A6 and A7 only explain how to set the analysis.
Then I have found this link, but it gives only few details:
https://knowledge.autodesk.com/support/inventor-nastran/learn-explore/caas/CloudHelp/cloudhelp/2020/...
thx
luca
up
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
Both analysis types use the same solver.
  • Explicit Dynamics solves the analysis using dynamics. The loads cause the parts to move, and the solution is the result of that dynamic motion.
  • Explicit Quasi-Static attempts to approach a static solution by using the dynamic solver but applying the loads as slowly as possible. For example, a duration of 0.1 seconds may be too fast (the kinetic energy is high), but 1 second may be close to approximating a static solution (because the kinetic energy is low.) During the process of determining "how slow approximates a static solution", the analysis is performed multiple times (so it can take longer to run). [Those times of 0.1 and 1 second are just made up. Since the time step is often on the order of 1E-6 to 1E-9, trying to reach a duration of 1 second with a time step size of 1E-9 would be a very long runtime! But I think from testing that even a "short" duration event often has a relatively low kinetic energy and therefore is a good approximation to a static solution.)
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Roelof.Feijen
Hi @Anonymous ,
The image below was taken from a youtube presentation about other FEA software. Hopefully this will bring even more clarity to when using implicit and when using explicit analysis.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Thx John and thx Roelof,
the table is clear; so it's matter of strain rate.
Now I'm wondering which is the difference between applying a Quasi-static analysis instead of a Non-Linear Static Analysis. Both analysis calculate strain and I should use them when I can think to my problem approximately as Static.
The solver is different the solution is calculated with different process but ideally are these two analysis similar?
I can't figure out when I should apply the first or the latter; yes, the strain rate of the Quasi-Static should be higher than the Non-Linear Static (as I understood) but it's a very thin line, no?
Since this post has been created to understand the meaning of these new analysis it would be good having some guidelines.
p.s.: I created an explicit analysis of a bullet but I'm having some problems so I'll create a specific post for it.
thx
luca
