Edge to edge surface contact separation in Non Linear Analysis
Hello All,
I was hoping I could get some guidance as to what is going on with this Non-Linear outcome.
I have this 20.6-meter-long x 1.6 meter tall I beam. Simply supported (Pin connection at left end and translation allowed at the right end-see attached fig.1). Also I have added frictionless constraints every 4 flanges to avoid displacement in the Z direction (The FEMAP example I am following uses bracing but I am not sure if you can do that in Inventor/Nastran, however I think frictionless is doing the same function). A distributed load of 130 kN/m is supposed to be added but distributed loads seem to be an issue with Nastran so a total load of 2600 kN was added (through the entire beam length- applied on the mid chord).
The material I have defined is type: Elasto-Plastic (Bi-linear). Initial Yield Stress: 235 Mpa. Youngs Modulus: 2.1E+11 (Pa).
A couple of notes:
- The model is assembled by a series of short surfaces, rather than a typical long top and bottom flange, and 1 long web (fig.2 attached for clarification)
2. I have defined contact as surface contact and checked "Specify Contact Regions" selecting the entire structure. See Fig.3 (before defining contact like this the analysis would not work at all, even running a Linear Static Solution)
3. Prior to running the Non-Linear Analysis, I ran a Linear Static one just to see if the model was stable. The analysis ran (see fig. 4). There are no surfaces separating at any point and the displacement outcome is similar to what I am supposed to obtain in the Non-Linear Analysis (judging by the results obtained in FEMAP ~1.4 meters, max. displacement)
4. I ran the Non-Linear Analysis with the following settings:
- Type: Non-Linear Static
- Contact type: Bonded. Tolerance: 0.0001
- Large displacements: off
- Increments: 30
- Non Linear material as defined above
MAIN QUESTION:
Why do surfaces separate in the non linear analysis whereas the linear analysis seems to deformed properly? (see fig.4, fig. 5 and fig.6 )
Fig. 4 Linear Analysis - Displacement outcome
fig. 5 Non Linear Analysis
Fig. 6 Non Linear Analysis - Close up
