Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Different initial temperature conditions in a transient heat transfer analysis
1 REPLY 1
PierreMalouf8976
226 Views, 1 Reply
PierreMalouf8976
I am simulating molten metal which has been poured in a slag car. The objective is to obtain the temperature profiles as the molten metal solidifies in the slag car. I am stuck because I cannot figure out how to set different initial temperature conditions to different parts.
More specifically, set the initial temperature of the molten metal to 3017 F and the slag car to 72 F which is ambient temperature. Unfortunately the analysis only allows a "global" condition.
I did find a procedure on the Autodesk web site which is,
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-set-up-a-tr...
However it seems very complicated and I have not been able to apply it.
Has anyone had a similar problem? If yes, how was it addressed?
Any help would be greatly appreciated.
Best regards,
Pierre Malouf
Consultant ferroviaire PM
Best regards,
Pierre Malouf
1 REPLY 1
anindo
in reply to: PierreMalouf8976
anindo
Hi @PierreMalouf8976
I don't know whether you ever found a solution to this query. I faced the same issue recently and found the suggested solution complicated. So I've put together a process note and written a Python script to automate the manual merging of the NASTRAN files described in the original solution. See this reply:
https://forums.autodesk.com/t5/inventor-nastran-forum/transient-heat-transfer-simulation-help-mug-of...
This works for me, perhaps it can help you as well.
Regards
Anindo Ghosh
Regards
Anindo Ghosh
