Mesh Convergence
lancermandc_co_za
Mesh Convergence
lancermandc_co_za
Hi All,
I'm very new to Inventor Nastran so please be gentle with me 🙂
How on earth do I get my mesh convergence plot to show anything but a straight horizontal line??
Replies (8)
John_Holtz
Autodesk Support
Autodesk Support
Hi @lancermandc_co_za . Welcome to the Inventor Nastran forum.
You mentioned the convergence plot was a "straight horizontal line". But the image shows a single point, and the model is setup for global mesh refinement (which produces a graph with a single point). Were you using the local mesh refinement instead of global mesh refinement when you got the straight line?
Regardless, whenever the automated convergence does not work, you need to refine the mesh manually. "Mesh > Mesh Control" and specify the smaller mesh size and locations. It looks like you just need to refine the faces around the inside of the outer holes. Since your model is symmetric and has a number of repeating patterns, you can refine each hole with a different mesh size! For example, one hole with a mesh size of 10 mm (giving 2 elements through the thickness), another hole with a mesh size of 5 mm, another with a mesh size of 2.5 mm.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
lancermandc_co_za
Hi John,
Firstly, thank you for taking the time to help me.
Whether I use global refinement or Local refinement, I either get a dingle point on the graph or a horizontal line (see attachment.
Could you walk me through obtaining an actual graph that represents convergence using my model?
John_Holtz
Autodesk Support
Autodesk Support
Sorry I was not clear. When the automatic convergence does not work, there is no way to make it work.
Instead, you turn off the automatic convergence and do a convergence study manually:
  1. Run the analysis with an initial mesh size.
  2. Enter the mesh size and result into Excel.
  3. Add Mesh controls to the model where the stress was high or where the stress gradient (change in stress per length) is high.
  4. Regenerate the mesh.
  5. Run the analysis.
  6. Repeat steps 2 through 5 until the graph levels off. Make sure that the location of the stress you write down is the same. In other words, you cannot use the max stress value if it changes from one location to another location in the model. (In your model, the max stress may move from one hole to another hole. Since everything is symmetric, that is not a problem as long as the position within the hole is the same.)
Note that some users are reporting that local mesh convergence worked in version 2024 but not in version 2025. I will have to do some tests. If I confirm that finding, I will report it to the development team.
John
John Holtz, P.E.
Autodesk, Inc.
lancermandc_co_za
Hi John,
Ok, that is much clearer now 🙂
Once again, thank you for your time to help. Much appreciated...
Hopefully the techies will figure out a way to program this feature to make it more user friendly....
lancermandc_co_za
I was just thinking, are you saying that Inventor can't create a convergence, but I can create one manually?
John_Holtz
Autodesk Support
Autodesk Support
I do not know if the "Mesh > Convergence Settings" is completely broken, or if it does not work on certain models. (I only hear about the situations where it does not work. 🙂).
Yyou can always specify mesh refinements at regions where you know you need a smaller mesh. Human intelligence (HI) may not be faster than artificial intelligence (AI), but at the moment HI is still better than AI, and better than pre-programmed logic.
"A" Convergence Settings
"B" Mesh Control
John
John Holtz, P.E.
Autodesk, Inc.
lancermandc_co_za
Just a bit of info again, I know (we all do) that Inventor's FEA meshing and Nastran meshing are very different in complexity so, what I did find is that Inventor's FEA is able to plot the convergence graph whereas Nastran cannot....
diego.rusnighi
Hi John,
I confirm the convergence has problems in 2025 ( also 2025.2). I opened a case
Best regards
Diego Rusnighi
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
