Defining the material properties of the honeycomb core
I want to do Linear Steady-State Heat Transfer Analysis to the honeycomb sandwich construction (HSC).
I think the honeycomb core is 3D Orthotropic material, so I think the material properties of the honeycomb core are different from that of the material of honeycomb core. I don't know the material properties of the honeycomb core.
I plan to use Aluminum 7075.
What should I do define the material properties of the honeycomb core?
Sincerely,
7515085
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
I do not know if HSC is something in the Nastran software, or if that is a standard industry term. But I will get to that later.
For the thermal conductivity, I assume that you are using solids in your analysis so that you can specify the thermal conductivity in 3 directions. (Shells and laminates only conduct heat in 2 dimensions.) So I assume that you have a solid block for the core and you want to enter the thermal conductivity to simulate the honeycomb. Here are some ideas:
  • Find a research paper or text book that describes how to calculate the conductivity based on the dimensions and properties of the honeycomb.
  • If a standard construction, maybe the supplier has conductivity data.
  • Perform a test to measure the conductivity.
  • Create a model of the honeycomb in full detail and analyze the heat transfer. Compare that result to a solid block and adjust the conductivity as needed to give the equivalent result.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Hi, john.holtz,
Thank you for your reply.
I'll try your advice.
If I have some trouble in the honeycomb analysis, I'll ask something again.
Sincerely,
7515085
