Hi all,
I am not a creep/viscoelastic expert, but there appears to be two different methods available in the Nastran solver:
- Creep has multiple methods for calculating the change in strain over time. The attached example "Inventor Nastran 2020 Users Manual (creep).pdf" is from the Nastran 2020 Users Manual and shows how to setup the model using the Nastran file. As far as I can tell, the Inventor interface does not provide access to the creep laws. (The Nastran Users Manual is available on the "offline help" pages. This link goes to the 2020 version. I'm sure there is a 2021 version, too.)
- Viscoelastic is for calculating the change in stress over time. This material can be accessed from the Inventor interface, but I am not aware of any examples that show how to use it.
In my experience, the biggest problem is finding the material properties. Without that information, you are not going to be able to analyze anything useful.
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
