- Mute
- Permalink
- Report
I was doing a tutorial from Nastran In-CAD Help:
http://help.autodesk.com/view/NINCAD/2017/ENU/?guid=GUID-955C0CC4-0F0E-42B4-8704-00A35A7AD14B
In 'Apply the Constraints' section we are fixing the lower center hole surface of the propeller, restraining it from moving and rotating in each directions.
My question is:
why we are not letting the propeller to rotate in one axis (in this case to rotate about lower center hole surface axis, probably it was X axis. I don't have access to Nastran In-CAD right now so I don't have how to check it in the model)? I was thinking that in normal modes analysis we need to constrain model, so we simulate its behaviour in real world. The propeller is rotating about its center axis and that's how I think it should looks like.
However, when I let the propeller to rotate about its center axis and run normal modes analysis the results are the same as in tutorial linked above.
Could someone help me in understanding this situation?
