Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Connect beam and shell elements
3 REPLIES 3
vanwees
1095 Views, 3 Replies
I am trying to simulate a plate which is welded to a beam. (see picture)
Is there an option to connect a line element with a shell element which is half way the line element.
Because I get everytime a fault e5000 which means it isn't connected to each other.
Thanks advance.
Labels (1)
3 REPLIES 3
Roelof.Feijen
in reply to: vanwees
Hello @vanwees ,
Take a look at this article. It describes exactly what you are looking for.
Where the line element and shell element connect, you need to select the edges of the surface.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
vanwees
in reply to: Roelof.Feijen
Hello Roelof
Thank you for the quick response. I have seen this article
But i think the problem is that the plate is connected half way the beam.
vanwees
Hello Roelof,
I have solved it with the article in combination with a rigid body.
Thank you
