I am trying to simulate a plate which is welded to a beam. (see picture)
Is there an option to connect a line element with a shell element which is half way the line element.
Because I get everytime a fault e5000 which means it isn't connected to each other.
Thanks advance.
Solved by vanwees. Go to Solution.
Hello @vanwees ,
Take a look at this article. It describes exactly what you are looking for.
Where the line element and shell element connect, you need to select the edges of the surface.
Hello Roelof
Thank you for the quick response. I have seen this article
But i think the problem is that the plate is connected half way the beam.
