Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Bug in Mesh.
2 REPLIES 2
309 Views, 2 Replies
Bug in Mesh.
It is a found pipe in the model.  The screenshot is from the stress VonMises plot.  I use actual deformation (1.0).
Nastran 2020 with latest updates are used. As we see the mesh affect the result.
2 REPLIES 2
Roelof.Feijen
Is this a statement? Do you need our help? What's the problem? Can you share the model with us for further research?
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
in reply to: Roelof.Feijen
Hi.
I do not need help.
Is there a bug, then it is a bug that Autodesk should fix in the software.
And if you are aware of the bugg, then this post is of not use. May Autodesk could roll out a update.
I found out that if I made a radius or somthing connected to the surfaces that not are correct meshed, then the meshing was better in the connected surface to the radius. (Walkaround)
My concern is whether I can trust the results that come from the software.
If there is a bug that is not fixed, what could be the consequences if the results not are correct.
If the manufactured part fails and damages people or the environment.
Autodesk would probably not admit any software problem if somthing in the real world accoure and decisions regarding component reliability is based on wrong basis due to bugs in the software.
