I want to Run a subassembly Ilogic rule from a top level, As well as making the rule wait before it runs so the form can update the parameters
JamesMeBoi
JamesMeBoi
Here is what I am looking for help with, I have a sub-assembly in my top level that is tooling for the machine. The tooling is an sub-assembly that has a form inside it which accesses the parameters of the sub parts in the tooling assembly. Between the 3 tooling parts, all the parameters are the same for the dimensions, it is comprised of 1 gasket and 2 metal forms.
Here is a break down of the current set up
Top Level: Rule
iLogicVb.RunRule("Tooling Assembly:1", "Tool Configuration")
Tooling Assembly(Sub Assembly) : Rule and Form
iLogicForm.Show("Tooling Configuration")
Parameter("BackplateThickness") = Parameter("BackplateThickness")
Parameter("Kanga Tooling Template Gasket Side:1", "BackplateThickness") = Parameter("BackplateThickness")
Parameter("Kanga Tooling Template:1", "BackplateThickness") = Parameter("BackplateThickness")
Parameter("Kanga Tooling Gasket Template:1", "BackplateThickness") = Parameter("BackplateThickness")
Parameter("ChevronAngle") = Parameter("ChevronAngle")
Parameter("Kanga Tooling Template Gasket Side:1", "ChevronAngle") = Parameter("ChevronAngle")
Parameter("Kanga Tooling Template:1", "ChevronAngle") = Parameter("ChevronAngle")
Parameter("Kanga Tooling Gasket Template:1", "ChevronAngle") = Parameter("ChevronAngle")
Parameter("ProductLength") = Parameter("ProductLength")
Parameter("Kanga Tooling Template Gasket Side:1", "ProductLength") = Parameter("ProductLength")
Parameter("Kanga Tooling Template:1", "ProductLength") = Parameter("ProductLength")
Parameter("Kanga Tooling Gasket Template:1", "ProductLength") = Parameter("ProductLength")
Parameter("ProductThickness") = Parameter("ProductThickness")
Parameter("Kanga Tooling Template Gasket Side:1", "ProductThickness") = Parameter("ProductThickness")
Parameter("Kanga Tooling Template:1", "ProductThickness") = Parameter("ProductThickness")
Parameter("Kanga Tooling Gasket Template:1", "ProductThickness") = Parameter("ProductThickness")
Parameter("ProductWidth") = Parameter("ProductWidth")
Parameter("Kanga Tooling Template Gasket Side:1", "ProductWidth") = Parameter("ProductWidth")
Parameter("Kanga Tooling Template:1", "ProductWidth") = Parameter("ProductWidth")
Parameter("Kanga Tooling Gasket Template:1", "ProductWidth") = Parameter("ProductWidth")
Parameter("SealSpacing") = Parameter("SealSpacing")
Parameter("Kanga Tooling Template Gasket Side:1", "SealSpacing") = Parameter("SealSpacing")
Parameter("Kanga Tooling Template:1", "SealSpacing") = Parameter("SealSpacing")
Parameter("Kanga Tooling Gasket Template:1", "SealSpacing") = Parameter("SealSpacing")
Parameter("SealWidth") = Parameter("SealWidth")
Parameter("Kanga Tooling Template Gasket Side:1", "SealWidth") = Parameter("SealWidth")
Parameter("Kanga Tooling Template:1", "SealWidth") = Parameter("SealWidth")
Parameter("Kanga Tooling Gasket Template:1", "SealWidth") = Parameter("SealWidth")
Parameter("TabLength") = Parameter("TabLength")
Parameter("Kanga Tooling Template Gasket Side:1", "TabLength") = Parameter("TabLength")
Parameter("Kanga Tooling Template:1", "TabLength") = Parameter("TabLength")
Parameter("Kanga Tooling Gasket Template:1", "TabLength") = Parameter("TabLength")
Parameter("TopAndBottomPercentage") = Parameter("TopAndBottomPercentage")
Parameter("Kanga Tooling Template Gasket Side:1", "TopAndBottomPercentage") = Parameter("TopAndBottomPercentage")
Parameter("Kanga Tooling Template:1", "TopAndBottomPercentage") = Parameter("TopAndBottomPercentage")
Parameter("Kanga Tooling Gasket Template:1", "TopAndBottomPercentage") = Parameter("TopAndBottomPercentage")
Parameter("TopAndBottomSpacing") = Parameter("TopAndBottomSpacing")
Parameter("Kanga Tooling Template Gasket Side:1", "TopAndBottomSpacing") = Parameter("TopAndBottomSpacing")
Parameter("Kanga Tooling Template:1", "TopAndBottomSpacing") = Parameter("TopAndBottomSpacing")
Parameter("Kanga Tooling Gasket Template:1", "TopAndBottomSpacing") = Parameter("TopAndBottomSpacing")
Parameter("GasketThickness") = Parameter("GasketThickness")
Parameter("Kanga Tooling Gasket Template:1", "GasketThickness") = Parameter("GasketThickness")
See Image attached
Parts: Parameters
See Image attached
bradeneuropeArthur
public StillRunning as boolean
StillRunning = true
StillRunning = false
Public sub main
if stillrunning is false then
your code here
end if
end sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JamesMeBoi
Getting the error,
"Rule Compile Errors in Tool Configuration, in Tooling Assembly.iam
Error on Line 1 : 'Public' is not valid on a local variable declaration."
Ralf_Krieg
Hello
Public variable declaration needs to be placed in class namespace.
Anyway, wouldn't it be enough to set the form option modal to true? The calling rule in main assembly call the rule "Tool Configuration" (and gives it control) in the sub assembly. This rule "Tool Configuration" opens the form. While your form is opened modal, the following code in rule "Tool Configuration" will not execute. Changing parameters within the form will apply to model. If you close the form, the code afterwards will execute. As long as your rule "Tool Configuration" in subassembly not finishes, the control won't get back to the calling rule in main assembly.
R. Krieg
RKW Solutions
www.rkw-solutions.com
