- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to add the horizontal and the vertical extent dimensions to a flat pattern view, but so far unsuccesfully. I'm pretty sure someone already has code for that... 🙂
I tried several approaches to find the outmost points, but my current approach is to intersect every drawing curve with the view boundary box lines to find the outmost points and create geometry intents on the found curve at the outermost point, to later add dimensions. But the problem is, sometimes the line2d.intersectwithcurve function does not return anything (unless using a huge tolerance, in which case it returns the wrong point) even though the curve does intersect with the line. Also, if the curve is a line parallel to the intersect line, it also doesn't return an intersection - but then how do I know if the lack of an intersection means a: there's indeed no intersection, or b: the two lines are parallel and coincident?
Anyway, some code showing how to do this would be helpful. Thanks!
Here's the current state of my code:
Private Function Extents(ByRef FlatPatternView As DrawingView)
Dim TG, BG, LG, RG As GeometryIntent
Set TG = Nothing
Set BG = Nothing
Set LG = Nothing
Set RG = Nothing
Dim UVH, UVV As UnitVector2d
Set UVH = ThisApplication.TransientGeometry.CreateUnitVector2d(1, 0)
Set UVV = ThisApplication.TransientGeometry.CreateUnitVector2d(0, 1)
Dim TL, BL, LL, RL As Line2d
Set TL = ThisApplication.TransientGeometry.CreateLine2d(ThisApplication.TransientGeometry.CreatePoint2d(FlatPatternView.Left, FlatPatternView.Top), UVH)
Set BL = ThisApplication.TransientGeometry.CreateLine2d(ThisApplication.TransientGeometry.CreatePoint2d(FlatPatternView.Left, FlatPatternView.Top - FlatPatternView.Height), UVH)
Set LL = ThisApplication.TransientGeometry.CreateLine2d(ThisApplication.TransientGeometry.CreatePoint2d(FlatPatternView.Left, FlatPatternView.Top - FlatPatternView.Height), UVV)
Set RL = ThisApplication.TransientGeometry.CreateLine2d(ThisApplication.TransientGeometry.CreatePoint2d(FlatPatternView.Left + FlatPatternView.Width, FlatPatternView.Top - FlatPatternView.Height), UVV)
For Each DrawingCurve In FlatPatternView.DrawingCurves
If TG Is Nothing Then
Set Intersect = TL.IntersectWithCurve(DrawingCurve.Segments.Item(1).Geometry)
If Not (Intersect Is Nothing) Then Set TG = FlatPatternView.Parent.CreateGeometryIntent(DrawingCurve, Intersect.Item(1))
End If
If BG Is Nothing Then
Set Intersect = BL.IntersectWithCurve(DrawingCurve.Segments.Item(1).Geometry)
If Not (Intersect Is Nothing) Then Set BG = FlatPatternView.Parent.CreateGeometryIntent(DrawingCurve, Intersect.Item(1))
End If
If LG Is Nothing Then
Set Intersect = LL.IntersectWithCurve(DrawingCurve.Segments.Item(1).Geometry)
If Not (Intersect Is Nothing) Then Set LG = FlatPatternView.Parent.CreateGeometryIntent(DrawingCurve, Intersect.Item(1))
End If
If RG Is Nothing Then
Set Intersect = RL.IntersectWithCurve(DrawingCurve.Segments.Item(1).Geometry)
If Not (Intersect Is Nothing) Then Set RG = FlatPatternView.Parent.CreateGeometryIntent(DrawingCurve, Intersect.Item(1))
End If
Next
Dim PT1 As Point2d
Set PT1 = ThisApplication.TransientGeometry.CreatePoint2d
PT1.X = FlatPatternView.Left - 1
PT1.Y = FlatPatternView.Center.Y
Set VDim = FlatPatternView.Parent.DrawingDimensions.GeneralDimensions.AddLinear(PT1, TG, BG, kVerticalDimensionType)
PT1.X = FlatPatternView.Center.X
PT1.Y = FlatPatternView.Top - FlatPatternView.Height - 1
Set HDim = FlatPatternView.Parent.DrawingDimensions.GeneralDimensions.AddLinear(PT1, LG, RG, kHorizontalDimensionType)
End Function
Inv 2018
