Rotate Sketched Symbol with iLogic
Hej
I would like to rotate existing Sketched Symbol with iLogic. I can scale it with this code, but I can't use the same to rotate.
For Each sketched As SketchedSymbol In oSheet.SketchedSymbols
      If (sketched.Name = "Snit_C") Then
          sketched.Scale = 2
        sketched.Rotate = 30
Next
It get error:
Error in rule: SymbolRul, in document: TS_FG_BR.idw
Det offentlige medlem 'Rotate' i typen 'SketchedSymbol' blev ikke fundet.
If anyone can help. It will be nice.
Lilia
philippe.leefsma
The correct spelling of the property is "Rotation" and not "Rotate".
Check the Help Files in case of a doubt.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Thank you, Philippe !!!
It has helped. The reason I spelled it that way in the program.
Regards, Lilia.
I want to achieve something very similar. I have a symbol on my drawing and I want a rule to change it's scale to match the scale of another view I have
Something like this:
SymbolScale ("Scaled Man") = ActiveSheet.View(View(2)).ScaleString
So far I have copy pasted what you have, see below but get errors
      If (sketched.Name = "Scaled Man") Then
          sketched.Scale = 2
sketched.Rotation = 30
End If Next
I'm very new to iLogic so don't really understand these errors:
Error on Line 1 : Type 'SketchedSymbol' is not defined.
Error on Line 1 : 'oSheet' is not declared. It may be inaccessible due to its protection level.
Maybe there's something even simpler I could do?
MechMachineMan
For Each oSheet As Sheet in ThisApplication.ActiveDocument.Sheets
For
Each sketched As SketchedSymbol In oSheet.SketchedSymbols If (sketched.Name = "Scaled Man") Then sketched.Scale = 2
End If Next
Next
Untested, but should work. You were missing the declaration for oSheet, as the plain english in the error stack suggests. oSheet needs a declaration as it is a variable created by the user and not native to the API.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for that explanation, it works perfect now for that appliction.
I've encountered another issue however, I want my sketched symbol scale to be set the same as another drawing view scale.
I have the following code but get this error: "Conversion from string "1/15.25" to type 'Double' is not valid."
For Each oSheet As Sheet In ThisApplication.ActiveDocument.Sheets
          sketched.Scale = ActiveSheet.View("ELEVATION").ScaleString
  Next
Next
 How can I convert this to a 'double'?
I have this piece of code which applies the scale from one view to another, which I've tried to use in a similar way above. However I understand in this instance it's simpler as I'm going from string to string.
ActiveSheet.View("PERSPECTIVE").ScaleString = ActiveSheet.View("ELEVATION").ScaleString
Soke too soon. No error when I remove the word 'String' from this line
