Insert parts list above titleblock
How can I change this code to insert the parts list above the title block
SyntaxEditor Code Snippet
If iProperties.Value("Summary", "Category") = "ASSEMBLY" Then
iLogicVb.UpdateWhenDone = True
' Set a reference to the drawing document.    ' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
' Set a reference to the first drawing view on    ' the sheet. This assumes the first drawing    ' view on the sheet is not a draft view.
Dim oDrawingView As DrawingView
Try
    oDrawingView = oSheet.DrawingViews(1)
Catch
    MessageBox.Show("No View found. Can not continue", "iLogic")
    Return 'return exits the rule
End Try
' Set a reference to th sheet's border
Dim oBorder As Border
oBorder = oSheet.Border
Dim oPlacementPoint As Point2d
If Not oBorder Is Nothing Then
    ' A border exists. The placement point
    ' is the top-right corner of the border.
    oPlacementPoint = oBorder.RangeBox.MaxPoint
Else
    ' There is no border
    oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(20, 20)
Dim oPartslist As PartsList
Try
    'look for the first parts list found on the sheet
    'if succesful finding it,
    'tell the user,then Do Nothing
    oPartslist = oSheet.PartsLists(1)
    MessageBox.Show("There is an existing Parts List", "iLogic")
Catch
    'if one is not found, Create it
    oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
End Try
Found something and played around with it.
adjust the offset to fit your title block.
Dim oSheet As Sheet
Try
Catch
    Return
End Try
Dim oPlacePoint As Point2d
    oOffset = 12.77 'user defined offset
    oX = oBorder.RangeBox.MaxPoint.X
    oY = oBorder.RangeBox.MinPoint.Y + oOffset
    oPlacePoint = ThisApplication.TransientGeometry.CreatePoint2d(oX,oY)
Else
Try
Catch
    ' Create the parts list.
    oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacePoint)
End Try
bradeneuropeArthur
Hi Measure first the location of the title-block and the inside dimension of the border.
for me the is 41.5 cm in X direction and 10 cm in Y direction.
use this as point values:
If iProperties.Value("Summary", "Category") = "X" Then
Dim oSheet As Sheet
Try
Catch
End Try
    'oPlacementPoint = oBorder.RangeBox.MaxPoint
	oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(41.5, 10)
Else
    oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(41.5, 0.5)
Try
Catch
    oPartslist = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
End Try
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
I want to  make the first statement apply to two different things "Assembly" and "Welding"
Do I have to write it as
and
ELSE If iProperties.Value("Summary", "Category") = "Welding" Then
It works this way, but have to copy the code twice.  Is there a better way
If iProperties.Value("Summary", "Category") = "ASSEMBLY"  Or iProperties.Value("Summary", "Category") = "WELDING" Then
