Ilogic to export sheet metal flat patterns from within a drawing
We have all singing and dancing Ilogic models that update, export dxf files (from assembly environment), drawings, etc. But for non-standard products we still rely heavily on spread sheet driven models which allows us to manually customise without breaking anything.
The models can be quite messy depending on the designer but the end result is a parts list. If there are any parts within the parts list that require a dxf flat pattern it is manually assigned a dxf file name in a column in the parts list and left blank otherwise.
Within the drawing environment is there anyway we can use Ilogic to look at the parts list and if it sees a row that has a dxf file name assigned it will export the sheet metal flat pattern of that particular part to a designated location?
Thanks in advance.
