iLogic and grabbing a value from excel matrix
steveh5
Advisor Advisor
Message 1 of 18
steveh5
Gang...
I created a rule which takes values from Inventor model and looks up a matrix in a spreadsheet and it works.
But, if it can't find a row...it keeps the values that were already there.
Is there a way to have it default to a value ("Please contact Engineering for a Material Number") if it can't find a row to match?
I'm thinking I need some type of If Then statement.
Here's my rule and the spreadsheet....
SyntaxEditor Code Snippet
If Shape = "Rectangular Tube" Then
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Rectangular_tube", "Matl", "=", Rect_Tube_Matl, "Shape_Size", "=", Shape_Size)
        Matl_Description = GoExcel.CurrentRowValue("Matl_Description")
        M_Number = GoExcel.CurrentRowValue("M_Number")
        iProperties.Value("Custom", "(Mat'l Description)") = Matl_Description
        iProperties.Value("Custom", "(Reference M#)") = M_Number
        InventorVb.DocumentUpdate()
    Else If Shape = "Square Tube" Then
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Square_tube", "Matl", "=", Rect_Tube_Matl, "Shape_Size", "=", Shape_Size)
Any help would be appreciated.
Thanks in advance,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Replies (17)
Message 2 of 18
Owner2229
Hey, are you familiar with Subs And Functions?
Basically, if you have any other code above or below the one you've posted, move it along with this update to the "Sub Main() ... End Sub":
Sub Main()
	Dim R As String = Update_Matl("Rectangular_tube")
	If R <> "OK" Then MsgBox(R)
ElseIf Shape = "Square Tube" Then
	Dim R As String = Update_Matl("Square_tube")
End Sub
Function Update_Matl(SheetName As String) As String
	Dim er_Message As String = "Please contact Engineering for a Material Number."
	Dim i As Integer = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", SheetName, "Matl", "=", Rect_Tube_Matl, "Shape_Size", "=", Shape_Size)
	If i = 0 Then Return er_Message
Dim Matl_Description As String = GoExcel.CurrentRowValue("Matl_Description") Dim M_Number As String = GoExcel.CurrentRowValue("M_Number") If Matl_Description = vbNullString Then Return er_Message If M_Number = vbNullString Then Return er_Message
iProperties.Value("Custom", "(Mat'l Description)") = Matl_Description iProperties.Value("Custom", "(Reference M#)") = M_Number InventorVb.DocumentUpdate()
Return "OK" End Function
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 18
steveh5
To answer your question simply...NO.
But, trying to learn.
I'll attempt to decipher and give it a whirl...
Thanks for the guidance/expertise!!!!!
Steve H.
Steve Hilvers
Message 4 of 18
Owner2229
You might also need to pass some other parameters to the function (like I did with the "SheetName").
It depends on where the variables come from.
Namely:
Rect_Tube_Matl
Shape_Size
If they're parameters, then it should be alright, but if they are variables from the rule, they'll need to be passed.
Let me know if you need furter assistence with this.
Mike
Message 5 of 18
Would a Try/Catch Block be helpful here?  Just a thought.
Message 6 of 18
Owner2229
The function that is looking for the row won't throw an error, it'll in fact return 0, so there's no error to catch.
You need to look at the returned value and discontinue the rule if it is 0, therefore:
Mike
Message 7 of 18
Thank you for clarifying that.  I am still somewhat new to programming outside of basic VBA stuff and I haven't quite grasped the concept of a Try/Catch block yet!
Message 8 of 18
steveh5
Again...Thanks for the help so far....
Kinda following your logic...not sure on exactly what the syntax is doing (not a code writer, so really cloudy), but making headway.....
The "Rect_Tube_Matl" and "Shape_Size" are parameters as you suggested.
I added your code to my rule (it's the only code in it).
When the code runs and can't find a row that matches the two dimensions of the matrix, the pop up note does show up. And, when a row is found, the message does not. Which makes sense.
The only thing is that the  "Matl_Description" and "M_Number" do not populate if the values are found like it does in my code.
I tried to add in an If / Then statement too but no luck.
If a value is found....populate the properties from the spreadsheet. If they aren't, I would like them both to say "Contact Engineering for Material".
Here's your code  with my edits in bold.
Sub Main()
End Sub
        Matl_Description = "Contact Engineering for Material"
        M_Number = "Contact Engineering for Material"
    Return "OK"
End Function
 Thanks again,
Steve H.
Steve Hilvers
Message 9 of 18
Owner2229
Alright, try it now. You can comment the red highlighted parts out by using aposthrophe if you don't want the Messages to pop-up.
Sub Main()
End Sub
    Dim oDescription As String = GoExcel.CurrentRowValue("Matl_Description")
    Dim oNumber As String = GoExcel.CurrentRowValue("M_Number")
    If oDescription = vbNullString Then oDescription = "Contact Engineering for Material"
    If oNumber = vbNullString Then oNumber = "Contact Engineering for Material"
    iProperties.Value("Custom", "(Mat'l Description)") = oDescription
    iProperties.Value("Custom", "(Reference M#)") = oNumber
If i = 0 Then Return er_Message Return "OK" End Function
Mike
Message 10 of 18
richard.joseph.pollak
I wrote something similar that stores people's initials in an excel file to auto-populate iProperties that fill out our title blocks. I'll insert my solution into your iLogic. Hopefully it can work for you. I also recommend you try to write your code more succinctly. There's no point in repeating yourself when you don't have to. Take a look at how I was able to shorten your If/Else If conditional.
Try
    Matl_Description = GoExcel.CellValue("C" & i) 'If the row does not exist in your excel file, this should fail and skip to the Catch portion
    M_Number = GoExcel.CellValue("D" & i)
Catch
    iProperties.Value("Custom", "(Mat'l Description)") = "Please contact Engineering for a Material Number"
    iProperties.Value("Custom", "(Reference M#)") = ""
End Try
Message 11 of 18
steveh5
Thanks for everyone's help...I could never get Mike's code to work, but I played around with my original code and did get the results I was looking for. May not be the cleanest, but it works for me.
I think it was  a combination of the code and the spreadsheet not grabbing values properly. From what I read, spreadsheets with empty rows don't play nicely...I ended up putting the default values in the top row. If a row could not be found, it defaults to the first row after the headers.
Anyway, here's what I ended up with ....spreadsheet is at end.
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Rectangular_tube", "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
'        If Matl_Description = vbNullString Then Matl_Description = "Contact Engineering for Material"
'        If M_Number = vbNullString Then M_Number = "Contact Engineering for Material"
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Square_tube", "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
    Else If Shape = "Plates" Then
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Plates", "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
    Else If Shape = "Flat Bar" Then
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Flat Bar", "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
    Else If Shape = "Mechanical Tube" Then
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Mechanical_tube", "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
Else If Shape = "Round Bar" Then
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Round_bar", "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
Else If Shape = "Hex" Then
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Hex_bar", "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
Else If Shape = "Channel" Then
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Channel", "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
Else If Shape = "Angle" Then
        i = GoExcel.FindRow("C:\ENGINEERING\ilogic\Shape_Generator_Raw_Material_Specs.xlsx", "Angle", "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
Steve Hilvers
Message 12 of 18
steveh5
Thanks Richard...was putting up my conclusion right when your reply popped up. I will take a look and see if I can't clean up my code. Appreciate the insight.
Steve Hilvers
Message 13 of 18
Dopey1993
Can I have a Inventor and excel sample file of this?
Thanks in advance
Message 14 of 18
MechMachineMan
Dopey, the code is shown and the excel file is attached, what more do you need?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 15 of 18
Dopey1993
I drew up a generic part and downloaded the excel file and copied the rule, replaced the file path with mine and it didn't do anything.
I am some what of a newbie so it might be a problem on my end.
Message 16 of 18
MechMachineMan
In your generic part, did you put a parameter called Shape, which is what the rule requires to make it's selection.
Much like the debugging outlined in the link in my signature, you can use messageboxes to figure out which lines are and aren't executing and then tackle the issue from there.
Justin K
Message 17 of 18
Dopey1993
Here is what I have.
Message 18 of 18
MechMachineMan
Dopey, you are missing parameters in your part file (Material & Shape_Size)
There are definitely better ways of doing this though; as you can have the parameters used to model the part also used to look up the part size in the spreadsheet, but that's another issue.
Also, I cleaned up the code to make it much, much simpler and easier to read, maintain, and expand upon.
Sub Main()
	Dim oSourceFile As String
	oSourceFile = "C:\Users\JRK\Desktop\Shape_Generator_Raw_Material_Specs.xlsx"
	Select Case Shape
		Case "Rectangular Tube"
			oSheetName = "Rectangular_tube"
		Case "Square Tube"
			oSheetName = "Square_tube"
		Case "Mechanical Tube"
			oSheetName = "Mechanical_tube"
		Case "Round Bar"
			oSheetName = "Round_bar"
		Case "Hex"
			oSheetName = "Hex_bar"
		Case Else
			oSheetName = oShape
	End Select
	i = GoExcel.FindRow(oSourceFile, oSheetName, "Matl", "=", Material, "Shape_Size", "=", Shape_Size)
	'If Matl_Description = vbNullString Then Matl_Description = "Contact Engineering for Material"
End Sub
Justin K
