Hey,
I'm using this i logic code for exporting all part lists on all the sheet that include inside the drawing.
I'm looking to adjust the i logic code to have more specific information in the excel file.
the drawing file :
all the sheets inside the drawing file has 6 part lists, 4 of the part list are the same in the all sheets, 2 part lists are changing every time.
I logic code that I'm using :
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document Dim oSheets As Sheets = oDrawDoc.Sheets 'get the path and name of the drawing file Dim fileName = ThisDoc.PathAndFileName(False) & ".xlsx" If (IO.File.Exists(fileName)) Then Dim result = MessageBox.Show("The file already exists: " & vbCr & vbCr & fileName & vbCr & vbCr & "Do you want to overwrite the file?", "File Exists", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) If result = vbYes Then IO.File.Delete(fileName) Else Exit Sub End If Else End If Dim startRow = 1 Dim includeTitle = True Dim PartsListNumber = 1 Dim oPartslist As PartsList For Each sheet As Sheet In oSheets 'Find every sheet in the drawing For Each oPartslist In Sheet.PartsLists 'Find every partslist on the sheet ThisApplication.StatusBarText = "Exporting Sheet " & Sheet.Name & " of " & oSheets.Count & " Please Wait!" ' create a new NameValueMap object Dim oOptions = ThisApplication.TransientObjects.CreateNameValueMap 'specify an existing template file 'to use For formatting colors, fonts, etc 'oOptions.Value("Template") = ThisDoc.Path & "\BOM Template.xlsx" 'specify the Columns To export(all columns need to be in the partslist) 'oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION" 'specify the start cell oOptions.Value("StartingCell") = "A" & startRow 'specify the XLS tab name 'here the file name is used oOptions.Value("TableName") = "PartsList-" & PartsListNumber 'without extension 'choose to include the parts list title row 'in this example "Ye Old List of Parts" is written to the StartingCell oOptions.Value("IncludeTitle") = True 'choose to autofit the column width in the xls file oOptions.Value("AutoFitColumnWidth") = True ' export the Partslist to Excel with options oPartslist.Export(fileName, PartsListFileFormatEnum.kMicrosoftExcel, oOptions) PartsListNumber = PartsListNumber + 1 Next Next Dim Complete = MessageBox.Show("All Done with Partslist Export" & vbCr & vbCr & fileName & vbCr & vbCr _ & "Do you want to open the file?", "Part List Export", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) If Complete = vbYes Then ThisDoc.Launch(fileName) Else Return End If
My issues with this i logic when I'm run it is :
I would like to have the part lists title
Instead of patrslist-1,2,3......
Second issue :
I would like to get the i logic code check the Duplication of repeating parts list in all the sheets and have it once in each excel file.
