iLogic and export Parts List in a IDW 2023
haitam.moslemane
haitam.moslemane
Hey,
I'm using this i logic code for exporting all part lists on all the sheet that include inside the drawing.
I'm looking to adjust the i logic code to have more specific information in the excel file.
the drawing file :
all the sheets inside the drawing file has 6 part lists, 4 of the part list are the same in the all sheets, 2 part lists are changing every time.
I logic code that I'm using :
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSheets As Sheets = oDrawDoc.Sheets
'get the path and name of the drawing file
Dim fileName = ThisDoc.PathAndFileName(False) & ".xlsx"
If (IO.File.Exists(fileName)) Then
    Dim result = MessageBox.Show("The file already exists: " & vbCr & vbCr & fileName & vbCr & vbCr & "Do you want to overwrite the file?", "File Exists", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
    If result = vbYes Then
        IO.File.Delete(fileName)
    Else
        Exit Sub
    End If
Else
End If
Dim startRow = 1
Dim includeTitle = True
Dim PartsListNumber = 1
Dim oPartslist As PartsList
For Each sheet As Sheet In oSheets 'Find every sheet in the drawing
        For Each oPartslist In Sheet.PartsLists 'Find every partslist on the sheet
               ThisApplication.StatusBarText = "Exporting Sheet " & Sheet.Name & " of " & oSheets.Count & "    Please Wait!"
           ' create a new NameValueMap object
        Dim oOptions = ThisApplication.TransientObjects.CreateNameValueMap
        'specify an existing template file
        'to use For formatting colors, fonts, etc
        'oOptions.Value("Template") = ThisDoc.Path & "\BOM Template.xlsx"
        'specify the Columns To export(all columns need to be in the partslist)
        'oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION"
        'specify the start cell
        oOptions.Value("StartingCell") = "A" & startRow
        'specify the XLS tab name
        'here the file name is used
        oOptions.Value("TableName") = "PartsList-" & PartsListNumber 'without extension
        'choose to include the parts list title row
        'in this example "Ye Old List of Parts" is written to the StartingCell
        oOptions.Value("IncludeTitle") = True
        'choose to autofit the column width in the xls file
        oOptions.Value("AutoFitColumnWidth") = True
        ' export the Partslist to Excel with options
        oPartslist.Export(fileName, PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
        PartsListNumber = PartsListNumber + 1
        Next
Next
        Dim Complete = MessageBox.Show("All Done with Partslist Export" & vbCr & vbCr & fileName & vbCr & vbCr _
        & "Do you want to open the file?", "Part List Export", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
        If Complete = vbYes Then
        ThisDoc.Launch(fileName)
    Else
        Return
    End If
 My issues with this i logic when I'm run it is :
I would like to have the  part lists title
Instead of patrslist-1,2,3......
Second issue :
I would like to get the i logic code check the Duplication of repeating  parts list in all the sheets and have it once in each excel file.
theo.bot
@haitam.moslemane
1) In your rule you have defined the Table name yourself:
you need to replace this with the title value of your partslist
        oOptions.Value("TableName") = oPartslist.Title
2) When you loop thru the partslists, you could check if there is already a partslist exported with the same file reference. create a new arraylist and check if the file reference already exists in the array. if not, add the file reference to arraylist and continue exporting.
Dim oParents As New ArrayList
If Not oParents.Contains(oPartslist.ReferencedDocumentDescriptor.FullDocumentName) Then oParents.Add(oPartslist.ReferencedDocumentDescriptor.FullDocumentName)
'excute export code ....
end if
Here's a new copy of your copy with these options:
    Else
        Exit Sub
    End If
Else
End If
Dim startRow = 1
Dim includeTitle = False
        oOptions.Value("TableName") = oPartslist.Title '"PartsList-" & PartsListNumber 'without extension
        oOptions.Value("IncludeTitle") = False
Else
	Logger.Info(Sheet.Name & ": there is already a partslist exported for file reference " & oPartslist.ReferencedDocumentDescriptor.FullDocumentName)
			End If
        Next
Next
    Else
        Return
    End If
haitam.moslemane
Thank you for your help.
The loop thru the partslists worked very good.
But the Title name rule didn't work.
I got this message :
When you click yes, will get the message one more time.
By clicking NO, will get this error :
theo.bot
Did you update your rule or did you copy the code i shared?
Can you share your drawing? that's easier to help you troubleshoot.
haitam.moslemane
I copied the code from your comment and tried to run the rule.
Second, i tried to run it with out the title rule.
I can't share my drawing, because it's belong to my work company.
Sorry
theo.bot
@haitam.moslemane
No problem, I checked it again and reproduced the issue. It means that the title of your partslist title is the same. I assumed from your screenshots that your titles where manually changed. I added a new check in the code.
Else
Exit Sub
End If
Else
End If
Dim oParents, otitles As New ArrayList
Dim startRow = 1
If Not otitles.Contains(oPartslist.Title) Then
otitles.Add(oPartslist.Title)
Else
oOptions.Value("TableName") = oPartslist.Title & PartsListNumber
End If
Else
End If
Next
Next
Else
Return
End If
haitam.moslemane
Thank you very much.
The problem solved
