Width Mate
Width Mate
I recently moved from Solidworks to Inventor, and the transition has been a smooth one in all ways but one: Inventor does not have a width mate feature to aid with assembly. A width mate allows the user to center a part, feature or component equidistant between two edges or planes on a different part, feature or component, without the need to sketch and mate additional center planes. It is not the same as the current Symmetry feature, because Symmetry does not allow the user to select different faces on the same part, e.g. centering a clearance hole between the top and bottom edges of a slot in another part. I've linked to a YouTube video with a demonstration of the width feature below.
https://www.youtube.com/watch?v=iFiPxAMmxKc
Of course there are other methods of centering assembly components that yield the same result, but those methods require opening individual parts and sketching new workplanes, or measuring then adding or subtracting diameters of slots or holes for an offset mate, etc. Adding a width mate feature would streamline workflows by eliminating these extra steps. This feature has been requested repeatedly for a decade now, as shown by the archived Inventor Forum post from 2011 and the Inventor Ideas post from 2013 linked below.
https://forums.autodesk.com/t5/inventor-forum/width-mate/td-p/2937346
https://forums.autodesk.com/t5/inventor-ideas/introduction-of-width-mates/idi-p/4352019
I sincerely hope this post can reach the developers so that this incredibly useful feature can be added as soon as possible. I also posted this request in the Inventor Forum for exposure.
3 Comments
didier.spinnewyn
You can use the joint command and the slide type then right click and select between 2 faces.
tburtonD9T8B
The joint slide command only allows this between two faces of the same component. The width mate if it existed should allow mating between two faces of two separate parts in an assembly.
tburtonD9T8B
My workaround is to create a mid plane  construction geometry inside the assembly, then use a plane inside the part that is a midplane, and mate those. The problem with this is that is the part you are mating doesn't have this midplane, and you can't check it out to create it, you must rely on other methods.
Technology Administrators
