Weld visibility in presentation
It would be a great enhancement of Inventor when it's possible to control the visibility of welds in a Presentation. In our products we have lots of welded sub-assemblies which have to be assembled according to a specific method. But if we make an exploded view, the welds dissappear, which looks very strange on an assembly-drawing!! see picture. Left is the presentation, right the assembly file.
46 Comments
asiu
I had similar issues with welded parts in a presentation file.
I was told by Autodesk that this is the intended Inventor behaviour with I respectfully disagree with. Why: it is an exploded view of welded parts and not the assembly for welding of one simple welded part pieces.
Weldments do not show up in a Presentation or ipn file.
tony
You mean welds are not visible in the .ipn environment right?
SerkanCicek
I was going to submit exactly this issue before I have searched and found this thread. I completely aggree with you; welded sub-assemblies look very strange on an assembly drawing. All workers always confuse with these drawings. Weld beads of a welded sub-assembly have to be seen in presentation. I cannot even think a situation that one would turn off the visibility of the weld beads of a welded sub-assembly in a presentation even if there were an option.
I completely agree with you. Weld beads should be visible in subassemblies and in my opinion it should be a "as designed" feature. Not the opposite of it.
By allowing the inclusion and exclusion of a weld bead in a representation and then calling up the representation in the presentation file this problem would be solved.
The best way to solve this is to add the same functionality to weld beads that parts and subassemblies have currently for inclusion and exclusion in a representation.
Currently, the weld bead can be suppressed.  This is an all or nothing.  It affects all representations and thus all presentations.
There is a thread that addresses this issue.  Please explore and give kudo's if possible
Dylan T. Rogers
dan_szymanski
Status changed to: Accepted
Accepted idea [524]. Thanks!
There is a similar idea that could be taken care of at the same time. The title of the idea is "selective weld bead in a representation view "
By allowing the inclusion or exclusion of a weld bead in representation view it can easily to a drawing view in the same manner as a regular drawing view
Dylan T Rogers
Sent via the Samsung GALAXY S®4 Active™, an AT&T 4G LTE smartphone
miechh
Aaah yes! Thank you very much Dan Szymanski, for accepting as an idea. What's the next step in the process of implementing this in Inventor? When can we expect this to be actual?
dan_szymanski
@Anonymous
Hi Dylan,
Yes - I have reviewed the "selective weld bead in reps" Idea and we have some different ideas for that one and would like to keep it seperate from this request for now. Thanks.
@miechh
Hi miechh,
Unfortunatley we cannot share the plans of where and when this gets implemented (due to revenue recognition).  Members of our internal beta community always have a better snapshot of what we have in store for the future.  If you are not yet a member, reach out to me via e-mail or personal message me on A360 and I will send you a invite to the Inventor internal feedback community.  Thanks - Dan
dan_szymanski
The following comments were ported from a duplicate listing that I merged into this one:
Weldments In a Standard.ipn (Presentation)
dhagen |  ‎07-24-2014 12:52 PM |
tony |  ‎08-03-2014 09:20 PM
DanSo selective weld bead is under consideration?  Any estimation when it will be included in the welding template? Dylan T Rogers
dan_szymanski
Hi @Anonymous,
Yes, it is under consideration and the request is formally being tracked within our internal database (product backlog).  As I stated before, unfortunatley I cannot share any details as to the "how" or "when" (due to revenue recognition) via this forum.  Thanks for understanding.
-Dan
dan_szymanski
We are refining procedures around idea status.  Changing this to Future Consideration.
miechh
Okay, thanks for changing the status to "Future consideration"! So this also means it isn't already implemented in Inventor 2018 and won't be in Inventor 2019? Can't wait for it to be implemented as our customers repeatedly comment on our strange looking exploded views for the last 10 years.
ShayaGhanbar
It would have been nice if this feature was implemented in Inventor!
Our clients have asked me multiple times if it is possible to show welds in a presentation file.
Any news? I have drawing showing 2 welded subassemblies bolted together and the exploded view which part goes where.
Assembled shows the welds. The exploded view does not. I cannot convince anybody here that this is not MY fault...
miechh
If anyone with Inventor 2019 can confirm this is still missing...
I can confirm that Inventor 2019 still does not show welds in presentation....
luken
It's sad that it hasn't been implemented in the 2019 release.
Does anybody know of anyone that actually agrees with Autodesk's stance on this? What are the reasons? I cannot think of any reason not to show a weld in a Presentation file...
There is a work-around: if your weldment is a simple assembly, then create a new ipt file. Start the Derive part process and select the welded assembly (weldment). During the importation, remove the components that aren't welds from the source assembly file and import with source textures checked. Then remove the link to the base component. Then verify that the weld(s) have the same origin point as the assembly file (they should automatically). If not, use Move Body to correction the relative location. Finally insert this new ipt file into the assembly and ground to origin. Because the 'weld' isn't a weld, merely an ipt file, it will show up in the Presentation file.
