Use Alt-V to change sketch visibility
In an assembly, I can use Alt-V to toggle visibility. Why can't I do the same for a sketch in a part? Why do I have to right click, then go down to Visibility? As it stands, I have a 3D mouse button set to object visibility in an assembly. I should be able to do the same for a sketch in a part.
7 Comments
A_Sima
add creation of keyboard shortcut for visibility. don't like click rmb, don't like marking menu. just let me define shortcut for this!
mflayler
You can use system visibility setttings, but there currently isn't a shortcut for individual object visibilities.
Ctrl+]
Alt+]
Ctrl+/
Alt+/
Ctrl+.
Alt+.
You can also modify these shortcuts in the Customize screen.
DRoam
This definitely needs to happen. The Visibility toggle is such a common command, it needs to be assignable to a keyboard shortcut.
It'd be good if Alt+V also worked for reference geometry in part mode as well.
dan_szymanski
Idea added to backlog for future consideration [735]. Thanks!
dan_szymanski
Status changed to: Accepted
Accepted idea [735]. Thanks!
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2023. Please review the Inventor 2023 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
