Taks Scheduler is massively outdated. Every time we update to a new Inventor version, I start the migration process, and it´s taking weeks.!
First og all the TS is not happy about too large folders, and some times just stops without telling why, it seems like it´s still running, but when you check the log, nothing has happend for several hours.
Because of this one will have to select smaller portions of a folder hierarchy, to slowly work through the main folder. it´s some real tedious detectective work. Here it would be nice if one could pick several folders in one go, but only 1 folder can be selected in each addition to the task. (we have several thousand folders)
Because this job takes so long one will have to keep an updated list over the folders, and tick each folder as it has been migrated.
If only Task scheduler could be running in the background grinding slowly away on the files, in a stable pace, i would propably be able to migrate in half the time, and then all files would actually be migrated.
Im sure Task Scheduler could work way better if it were prioritzed.!
In general. I think i speak on behalf of most Inventor users when i say, stop making new things and make the things work, that are already there.!
