IMPROVEMENTS TO BE ABLE TO MAKE ABOUT JOINT COMMAND
* Isn't it an error joint command have been coming up with automatic playing as default? I have to close it whenever I open Inventor again and I can't find to close it any setting place as default. Sometimes it can be waste of time to close it for big assemblies. Besides, joint command comes as rotational option is default. But many uses it as rigid is default.
* I want to be able to use editing of rigid command same with Mate command's on browser. Because it is very easy and perfect work to edit mate command. To be able to edit rigid command, we have to double click on browser and select the connect value. But when we select a mate on browser, its value appears in small text box as selected. I'm sure everybody use this function happily. I think this can be possible for joint command.
*Similarly with previous problem, it is a bit hard for me to edit of offset origin values for rigid. can this be fix on browser with some nice visuals?
