Show only
Search instead for
thank you for your feedback. Unfortunately we can't reproduce it on our side even if we use Czech localized Inventor 2022 - tested with defeult templates and with application settings for Drawings - to use by default Inventor *.idw files.
Could you send to us your dataset (with project file), please ? You can send data directly to my email : [email protected] .
do you try to use the quick access bar to create new files? That won’t work in 2022 if you just migrated your old templates. In the new version all templates have been renamed to “Standard.*”. Happened to me as well (in the German version.) You will have to rename your templates.
Hi Rajko, of course, I migrated the templates and I also found that there were Standard templates in the folder C:\Users\Public\Documents\Autodesk\Inventor 2022\Templates\cs-CZ, for the first time in the 26th version of Inventor. Until then, "Norma" templates have always been used for Czech Inventor. I believe that Autodesk about this news could at least inform their partners to avoid embarrassment for customers who will be migrated their templates and run them from the Home opens something else entirely. It is not a problem to rename the template to Standard, but will it be valid for other versions as well? Regards
@UncleStan & @RajSchmidt , many thanks for the feedback! We have documented the best practices in the Help document, and hope it helpful for the users to take care of it.
