In the likely instance that tube and pipe hasn't been completely overhauled for the 2020 release I would like to see a ''refresh all connections'' command added to the tube and pipe environment. Individual connections often fail to update when a connected pipe moves, leaving them in position until you ''edit connection'' and toggle between the connections. I also reset them by editing connection and toggling between "user defined" 0 and 0mm. Fine in a single situation but when there are 20 to do in a run it's tedious and effectively less parametric than Plant3D (my alternative for pipe modelling).
I thought about creating a screen-cast of this but I'm confident anyone who uses tube and pipe regularly will know what I'm talking about. I've noted this happening with both generic Inventor CC parts and my own authored components.
Cheers,
