Tube&Pipe 087: “TP Save Dialog Pop-up”
Fix saving pop-ups. Saving of Runs, Routes is only allowed at T&P asm level, if I hit save the pop-ul should ask me if I want to save the whole TP asm and the same for Make Adaptive. Right now if I try and Make Adaptive a route I get “Save original Run first”, then I try to save the run and I get “Save it in main TP context” so I need to step up, save, return, make adaptive. Way too many steps. The message should be “Main TP assembly will be saved first. OK, CANCEL”.
@dan_szymanski
