Trim/Extend Frame Generator members to members with curved faces
You should be able to trim or extend a frame member to the face of a curved frame member
14 Comments
BryanKelley
I want Frame Generator to be able to work with curved frame objects correctly
Tags (6)
Bryan,
Can you explain in detail what happens incorrectly?
Josh
BryanKelley
Hi Josh,
  I want to be able to Trim, Extend, Lengthen, Shorten, Miter, and Notch any frame member regardless if it is curved or straight.  I should be able to use either definition when selecting the start/end or other condition that the frames need to use.
Bryan
LT.Rusty
The other thing that's annoying with Frame Generator is that any curved elements you create, the curved part is separate from the straight part.  If I want a piece that's 60 inches long with a bend at the end that's got a 6" radius, it'll give me a 54" straight part and a part that's a 90 degree bend with R6, rather than a single piece of bent steel.
dan_szymanski
Status changed to: Accepted
Accepted idea [US7700]. Thanks!
MTimmis_ADSK
Same request here please, trim to curved face using the trim/extend command in Frame Generator.
Jef_E
I also would like to see this implemented.
sjxyz
So would I!
Huib_ManageCAD
I would like to be able to trim members using a curved surface. Straight surfaces are no problem. However I need to trim members to curved parts all the time. I would like to gather support for this problem
Please hit the "vote up" button!
Tags (5)
dan_szymanski
Status changed to: Gathering Support
dan_szymanski
Idea added to backlog for future consideration [13850]. Thanks!
dan_szymanski
This idea has been implemented within Autodesk Inventor 2021. Special thanks to everyone who cast a vote for it.
dan_szymanski
dan_szymanski
This idea has been implemented within Autodesk Inventor 2021. Two new zoom controls have been added to the property panel when inserting or editing frame members. These controls will make frame member offset values and rotations easier to interpret. Special thanks to everyone who cast a vote for it.
