Torx screws in content center
Add metric and imperial Torx screws to content center please.
I might just not be looking hard enough, or it might be in 2015, but I can't find them.
25 Comments
Hi @jingyi.liu:
I added the screw sizes M2/M2.5/M3/M4/M5 to ISO 14581 according to the sizes available at  https://eu.shop.bossard.com in the following manner:
NND = Nominal Diameter ==> M Size
NLG = Nominal Length ==> From Bossard Table "L"
GEL = Thread Length ==> manual tuning
KOD = Head Diameter ==> From Bossard Table "d2,max"
KOH = Head Height ==> From Bossard Table "k,max"
STI = Groove Depth ==> From Bossard Table "t max."
GAL = Thread Run-out 45 ==> scaled with size, i.e. from M5 to M6 the values from the M6 screws is multiplied by (5/6) to generate the M5 value.
EPV = Insert-distance ==> scaled with size, i.e. from M5 to M6 the values from the M6 screws is multiplied by (5/6) to generate the M5 value.
BDM = Schank Diameter ==> from ISO Table
EO = Width Across Corner ==> From Bossard Table "A~"
SW = Width Across Flats ==> "Width Across Corner" divided by 1.4
RRK = Radius ==> scaled with size, i.e. from M5 to M6 the values from the M6 screws is multiplied by (5/6) to generate the M5 value.
R = Radius ==> because of the lack of information I just guessed this value
THREADDIA = Nominal Diameter ==> M Size
PTC = Pitch ==> from ISO Table
I'm happy to share the modified Torx Screw library file, it's available here.
Best regards
Christoph Gammeter
dan_szymanski
This idea has been implemented within Autodesk Inventor 2020. These screw types have been made available within the ISO content libraries. Special thanks to everyone who cast a vote for it.
danmachen
This link is dead and where is the update Autodesk?
We're moving into version 2021 now and this isn't here. Can we have these features in Inventor content center please? Its been 3 years! Can someone confirm this is available in 2020?
jingyi.liu
@danmachen
Yes, these contents are available in Inventor 2020. You can search ISO 14579/14580/14581/14582/14583/14584/14587 in Content Center...image.png
Valex269
Hello Jingyi, I got the: Unauthorized Sorry. You don't have permission to access this page. when I tried to follow your link. I really need a Torx library for a project I work on. Please let me know what can I do to have access. I logged on with my Autodesk account. Thank you! @Anonymous
