Hello! I am constantly faced with the need to reflect assembly components relative to the plane so that they are fixed, but not artificially. In 5 years, in different versions, I always observe the same problem - when components are mirrored, they lose dependencies.
Is it possible to implement a mirror reflection algorithm in an assembly as in part mode? For example, to make components have the same values on two axes, and on the third axis to have double distance of components to the symmetry plane... Is this possible? I'm sure it's easy in terms of programming algorithms!
I'm begging you very much, implement this algorithm! It is very uncomfortable to work without this functionality, because you always have to find other ways to solve the problem.
