Adding a new mode for a circular array in an assembly or repairing a fixed mode
Hello! Often there is a need to create a circular array of an assembly component with the same pose around an axis with the possibility of animation. A clear example is the Ferris wheel, where the cabins have to keep the same pose even during animation.
In this situation, tried to use fixed mode, but it does not allow to animate the array of components, as it comes off the axis of rotation (all components exactly repeat the trajectory of the original, which is not necessary at all).
In the mode "with rotation" components do not go off the axis of rotation, but change their position, which is also completely unnecessary.
Please make a new mode, where all the components of the assembly will be with the same pose and at the same time did not repeat the trajectory of the original during the animation. Or fix fixed rotation mode.
