Show only
Search instead for
Submitted byAnonymouson10-03-202112:05 PM
Status:
Gathering Support
The center of rotation problem when using "Shift+Mid-Mouse" orbit mode in Inventor.
I think the center of rotation should change automatically during the orbit command (like Fusion 360). Especially when I get close to the object and use the orbit command, the object rotates completely. It shouldn't be this hard.
Have you tried selecting said object you would like to rotate around? If nothing is selected you will rotate around the entire assembly. But, if you select a part within the assembly, it will rotate the entire assembly around the selected part.
