Show only
Search instead for
The Event Trigger "Part Geometry Change" for part documents is only available in This Document tab. It would be helpful if it was also available under the Parts tab for global use instead of having to set it per part document.
Agreed! This would be especially useful for sheet metal parts. When changing sheet metal styles many model parameters get changed, which then causes any code using the "Any Model Parameter Change" trigger to run multiple times. Those using the "Part Geometry Change" trigger only run once. I tested this out and on a relatively simple part (4 sided double break panel) the Any Model Parameter Change triggered 50 times.
